00001 /********************************************* 00002 * Chip type : ATmega16 00003 * Clock frequency : 4,000000 MHz 00004 Poort1 --> DCE Modem (poort bij open gedeelte) 00005 Poort0 --> Computer (poort bij MAX232 chip) 00006 *********************************************/ 00007 #include <avr/io.h> 00008 #include <avr/interrupt.h> 00009 #include <avr/signal.h> 00010 #include <inttypes.h> 00011 #include "lcd.h" 00012 #include "led.h" 00013 #include "RS232.h" 00014 #include "init.h" 00015 #include "status.h" 00016 #include "NMEA0183Parser.h" 00017 #include "GSMParser.h" 00018 00019 00020 typedef volatile unsigned char BYTE; //definitie type BYTE 00021 typedef volatile unsigned int WORD; //definitie type WORD 00023 // Defines 00025 #define STOP_TIMER0 TCCR0 &= 0xF8 00026 #define START_TIMER0 TCCR0 |= 0x05 00027 #define STOP_TIMER1 TCCR2 &= 0xF8 00028 #define START_TIMER1 TCCR2 |= 0x05 00029 00030 00032 // Global Varibles 00034 WORD Ticks256; 00035 WORD Ticks512; 00036 00037 int bufferwritepos = 0; // de schrijf positie van de buffer (GPS) 00038 int bufferreadpos = 0; //de lees positie van de buffer (GPS) 00039 int bufferwriteposGSM = 0; // de schrijf positie van de buffer (GSM) 00040 int bufferreadposGSM = 0; //de lees positie van de buffer (GSM) 00041 char lexeme[100]; //de buffer van de GPS 00042 char GSMlexeme[60]; //de buffer van de GSM 00043 00049 SIGNAL(SIG_OVERFLOW0) 00050 //ISR(TIMER0_OVF_vect) 00051 { 00052 // 256 ticks have gone by 00053 Ticks256++; 00054 // If you do the math you'll find that if the interrupt goes off 275 times, a minute has passed 00055 if (Ticks256 == 200) 00056 { 00057 led_toggle_green(); 00058 Ticks256 = 0; 00059 } 00060 } 00061 00062 00068 SIGNAL(SIG_OVERFLOW2) 00069 //ISR(TIMER0_OVF_vect) 00070 { 00071 // 256 ticks have gone by 00072 Ticks512++; 00073 00074 00075 // If you do the math you'll find that if the interrupt goes off 275 times, a minute has passed 00076 if (Ticks512 == 200) 00077 { 00078 showFixstate(); 00079 led_toggle_red(); 00080 Ticks512 = 0; 00081 } 00082 } 00083 00089 void ConfigureDevice () 00090 { 00091 00092 00093 00094 cli(); // disable interrupts just in case 00095 Ticks256 = 0; 00096 Ticks512 = 0; 00097 00098 // configure PORTB... and other settings 00099 00100 TCNT0 = 0x00; // clear Timer/Counter 0 00101 TCNT2 = 0x00; // clear Timer/Counter 2 00102 START_TIMER0; 00103 START_TIMER1; 00104 00105 // enable interrupts on timer 0 overflow 00106 TIMSK |= _BV(TOIE0); 00107 // enable interrupts on timer 2 overflow 00108 TIMSK |= _BV(TOIE2); 00109 00110 00111 00112 sei(); // enable interrupts 00113 } 00114 00115 00117 00122 SIGNAL (SIG_USART0_RECV) { // USART RX interrupt 00123 unsigned char c; 00124 c = UDR0; 00125 if (bufferwriteposGSM==60) 00126 { 00127 bufferwriteposGSM=0; 00128 GSMlexeme[bufferwriteposGSM]=c; 00129 bufferwriteposGSM ++; 00130 } 00131 else 00132 { 00133 GSMlexeme[bufferwriteposGSM]=c; 00134 bufferwriteposGSM++; 00135 } 00136 00137 } 00139 00141 // 00147 SIGNAL (SIG_USART1_RECV) 00148 { 00149 unsigned char c; 00150 c = UDR1; 00151 if (bufferwritepos==100) 00152 { 00153 bufferwritepos=0; 00154 lexeme[bufferwritepos]=c; 00155 bufferwritepos++; 00156 } 00157 else 00158 { 00159 lexeme[bufferwritepos]=c; 00160 bufferwritepos++; 00161 } 00162 } 00164 // 00171 int main(void) { 00172 //initialisatie leds 00173 led_init(); 00174 00175 //initialisatie timers 00176 ConfigureDevice (); 00177 00178 00179 //lexeme vullen met ~ teken om producer/consumer probleem tegen te gaan 00180 int i = 0; 00181 for (; i<99; i++) 00182 {//lexeme vullen met het teken ~ 00183 lexeme[i]='~'; 00184 } 00185 00186 //GSMlexeme om dezelfde rede vullen 00187 int a = 0; 00188 for (; a<59; a++) 00189 { 00190 GSMlexeme[a]='~'; 00191 } 00192 00193 //initialisatie van LCD disply 00194 InitLCDText(); 00195 00196 //rode led aan (init voltooid tot zover) 00197 led_red_on(); 00198 00199 //initialisatie UARTS 00200 InitUarts(); 00201 00202 //initialisatie GSM module 00203 initGSM(); 00204 00205 //sendTestSMS(); 00206 00207 //Initialisatie van NMEA0183 Parser 00208 initNMEA(); 00209 00210 //Initialisatie van GSP Parser 00211 InitGSMParser(); 00212 00213 //geel ledje aan (init voltooid) 00214 led_yellow_on(); 00215 00216 while (1) { 00217 00218 //Buffer van NMEA parser voeden indien lees en schrijf positie 00219 //niet gelijk zijn, en de entry nog niet is gelezen. 00220 if (lexeme[bufferreadpos]!='~'&&bufferreadpos!=bufferwritepos) 00221 { 00222 // uart0_putc(lexeme[bufferreadpos]); 00223 NMEAFeedBuffer (lexeme[bufferreadpos]); 00224 lexeme[bufferreadpos]='~'; 00225 bufferreadpos++; 00226 if (bufferreadpos==100){ 00227 bufferreadpos=0;} 00228 } 00229 //buffer van de GSM parser voeden indien less en schrijf positie 00230 //niet gelijk zijn en de entry nog niet is gelezen 00231 if (GSMlexeme[bufferreadposGSM]!='~'&&bufferreadposGSM!=bufferwriteposGSM) 00232 { 00233 GSMFeedBuffer (GSMlexeme[bufferreadposGSM]); 00234 GSMlexeme[bufferreadposGSM]='~'; 00235 bufferreadposGSM++; 00236 if (bufferreadposGSM==60) 00237 { 00238 bufferreadposGSM=0; 00239 } 00240 } 00241 00242 } 00243 return 0; 00244 }
1.5.3
